Daveb40258
Could not have said this any better Thank you!!
I think I have to threads going at once . My bad I'll answer in the other thread and reply directly there.
Apr 18, 2024
Daveb40258
You have to use a long nose pair of 18" Hemostats or a deep well spark plug boot puller. And no, you are not the only one with this...
Apr 18, 2024
Steering Concern
The subframe bolts require a torque procedure that is reminiscent of tightening down a cylinder head to the engine block.
Apr 18, 2024
2016 Titanium HB 1.6L 111k miles HELP
CRC chemicals company even offers a combo kit with enough for one cleaning session! Aptly named the "performance twin pack"! Im also...
Apr 18, 2024
The oil sure can migrate through the PCV system on these engines! I use CRC chemicals throttle body and upper intake cleaner on my...
Apr 18, 2024
Daveb40258
Mercurios2011's post
Hey everyone Louisville Kentucky USA here
You have come to the right place , someone ,somewhere either done it or is working on it , we may not know everything but we share what...
Apr 18, 2024
Daveb40258
Welcome to the forum. Browse through the threads, there are lots of nuggets of knowledge and experience in this forum!
Apr 18, 2024
Daveb40258
Hey Andy, Thanks for forwarding that post to me I must have read it 20 times. I did a lot of the repairs and troubleshooting mentioned...
Apr 18, 2024
Daveb40258
2016 Titanium HB 1.6L PCV VALVE LOCATION
One item I see but not sure how this is getting shown or measured, but the vacuum - in Hg, that value appears to be pretty low - so...
Apr 17, 2024
Daveb40258
When you have CEL that disappear on their own. You have ground connections that need to be cleaned and treated with Vaseline! I dont...
Apr 17, 2024
Daveb40258
Take it back. The job isn't done if the car isn't drivable. Wrong sensor, or else the computers are reading it wrong.
Apr 17, 2024
Daveb40258
Camshaft position sensors can be a very troublesome component from the aftermarket. I dont understand why they would be. They are...
Apr 17, 2024
Daveb40258
The PCV valve is at the engine block - where the intake meets the cylinder head - locate that gap between Cylinders 2 and 3 - then you...
Apr 17, 2024
Daveb40258
Good luck with this, hopefully it will be some simple cleanup of the oil splash and you should be able to use some carb cleaner to help...
Apr 17, 2024
Joedfordedgest
Transmission Whine
2019 ST 2.7 eight speed transmission. Have had and still have a whine while cruising 35 to 50 mph. Disappears with slight acceleration...
Apr 17, 2024
