Techman
fuel pressure damper
ys4z-93280-fa replacement, fixes, delete.
Apr 7, 2025
Active city stop not available
That feature was not available in North America. But I would recommend that you trace the circuit and check the quality of the negative...
Apr 7, 2025
Guitar995
I have a Ford fiesta titanium x 2016 and Everytime I turn on the car this message pops up. Sadly I have looked it up but not found too...
Apr 7, 2025
trd
How to find/remove seat stops on Fiesta Mk5 seat runners?
Hello, I just bought a Mk5 Fiesta Zetec 2008 and need to gain an inch+ more legroom. Before I took out driver seat, I removed passenger...
Apr 7, 2025
Windshield Washer Issue
Thanks! I'll do more thorough testing. Hum from the motor in both polarities is on the bench, off the car. It only hums with rear...
Apr 6, 2025
Got to love a Puma
Puma owner
Hi everyone! As the thread title and my username suggest I’m a Puma owner! Lucky enough to own an 11k one owner from new Puma 1.7 in...
Apr 6, 2025
I thought Forscan could actuate features through the GEM since pump relays are in the GEM. I spent time with it and observed: - rear...
Apr 6, 2025
Drum brakes park brake adjustment?
Thanks for all that! Whew! I turned out the star wheel until it took effort to install the drum then made sure the wheel still spun...
Apr 6, 2025
CAVPILOT
2015 Fusion losing power
Apr 6, 2025
2013 Fiesta Radio not working
That is the point I'm trying to bring up. In a word, yes - it can be done (ok, 5 words) but if you work with a local installer, they...
Apr 5, 2025
Yes, your "single DIN" keypad is replaced - you have the "OK" button and it's cursor, you'll have the LOCK and the Warning Flasher...
Apr 5, 2025
Q
qmfosejs
Hey long shot, but did you ever get it to work? I am dealing with the same problem and cant figure this out
Apr 5, 2025
CAVPILOT
NOOB
Greetings to all. Received my car in a will from my Mom. Great little car and have had ZERO mechanical problems after 109,000 miles...
Apr 5, 2025
CAVPILOT
NOOB here and just came across this. Mine had the SAME symptoms...loss of power on acceleration and sputtering. My fix was as simple as...
Apr 5, 2025
Wheels, Tires, Chasis, Brakes & Suspension
I replaced the brake shoes and cleaned everything along the way. With new shoes in place, the park brake barely grips where it used to...
Apr 4, 2025
