Washer problem.
Welcome to the forum. Feel free to use the search function to find threads that might correspond with the same problem you have. If you...
Apr 21, 2025
MRBLawnguy
Diagnostics help!!
We have a 2019 Fiesta SE with codes p2112 throttle actuator control system stuck closed, p0351 p0352 ignition coil A/B (all 4 ignition...
Apr 21, 2025
Butch
Washer problem.
Have water to rear window but none to front. No sound of pump operating front washer.
Apr 21, 2025
Stately's post
Headlight beam shooting out 90° to the car
Yes! Ok, so that’s pretty much exactly what I played around with yesterday, removed the headlight and really took a good look. The...
Apr 20, 2025
NeedForSpeed3685
What is this please
My climate control mysteriously stopped working, recently. I checked fuses and relays, and even replaced the climate control module. In...
Apr 19, 2025
NeedForSpeed3685
What is this please
Your AUTO ambient light sensor for nite-time illumination... C1BZ-13A018-A - It's called a "Sunload Temperature Sensor" Works when...
Apr 19, 2025
NeedForSpeed3685
Peculiar Climate Control power issue
2013 SE 5-speed, standard climate control Replaced climate control module and checked all fuses/relays. Verified voltage at harness...
Apr 19, 2025
Stately
Apr 18, 2025
That's a really good car. If you haven't, it might be a good idea to change the transmission fluid. How many miles?
Apr 18, 2025
Keith_in_Kingman's post
Hello. I drive a black 2019 SE with a manual transmission. I'm in Kingman, Arizona.
Apr 18, 2025
Stately's post
Awesome, thank you. Anything in particular I should look for when the light is out? I removed just the bulb earlier but it didn’t make a...
Apr 18, 2025
The light may be from loss of the Lens hood, lampshade the low-beam bulb uses to confine the beam and the light to the cup the reflector...
Apr 18, 2025
Keith_in_Kingman
CD Lens Cleaner
Hello all. My cd's have been skipping so I bought a Maxell cd lens cleaner. However, the cd player continually ejects the cleaner disc...
Apr 18, 2025
Keith_in_Kingman
Apr 18, 2025
Stately
Apr 17, 2025
