matayo47
p0016
I'm at a loss rn. I've got a 2011 1.6L with a p0016 code. I bought the car from someone who had timing issues with it. originally when I...
May 13, 2025
Nicks
Key not detected
Hi. I have a 2016 eco boost. I have just replaced the plastic parts of the key fob and put the little circuit board in top half of the...
May 13, 2025
LionsTooth
Welcome!
May 12, 2025
LionsTooth
JoeBob's post
Hello. I recently purchased a 2018 Fiesta SE. Bought it after my 1991 Geo Metro's transmission went to hell in a handbasket. And...
May 12, 2025
velton
Noisy Exhaust
Recently I had to replace the rear silencer on my Fiesta. The garage fitted a Motorcraft one but it is extremely noisy. Has anyone had a...
May 12, 2025
Rear bumper cover rivet size?
The rivets on the rear bumper cover mounting brackets and the impact absorber are what appears to be aluminum. I just don't know what...
May 11, 2025
Try here to help you - LASCO - they are a local supplier around my area - they may be able to supply or at least identify - what you...
May 11, 2025
If you visit the Ford dealership parts department they will be able to fix you up with the proper size rivits. They aren’t for the...
May 11, 2025
From that diagram, it looks like Ford doesn't even have the #9 rivet in its list, if that's even what I need argh!! I guess I'm gonna...
May 11, 2025
Remove and Replace Transmission
2013 SE 5 speed manual 1.6 Hatchback. Bought new. Popping out of 1st gear sometimes. Not the usual problems, shifter, motor mounts, etc...
May 10, 2025
Guitar995
Active city stop not available
Good afternoon! I have some fantastic news. It works! I plugged it into the car and the car recognize it immediately, I can now modify...
May 10, 2025
Q
Quick71
Crank but no start
Hey all i currently have a 2007 ford focus se 2dr hatchback with crank but no start. I've changed fuel pump fuel filter crankshaft...
May 9, 2025
Rowdy09
Bilstein B6 struts and shocks. If you are installing them, post impressions and questions here....
I would love to put lowering springs on mine. Sure its not a just switch in and out
May 9, 2025
I was reading the Bilstein website product description. They state that the B6 is matched to O.E. shock and strut Dimensions. I took...
May 9, 2025
2015 Fiesta 1.6l N/A Catalytic Converter (Canadian car)
hi there , part number 674 927 is made by dorman and way cheaper than any OEM or aftermarket cat assys hope this helps
May 9, 2025
