Dum B
2015 SE 1.6 Overheating @idle +A/C blowing warm air
Hello @hamhawk, Were you able to solve your issue? Can you share what the cause is? Thank you
May 15, 2025
2012 Fiesta Sedan A/C Compressor
Ok. I think I may just replace the fan. It's not that expensive on eBay or Amazon. I'm not about putting very expensive Motorcraft parts...
May 14, 2025
The fan wire connector itself started smoking when I hit the ac button in my car. No hot air even though the system seems to be...
May 14, 2025
O
owboky
2007 Ford Focus HVAC
I have a 2007 Ford focus. I pulled apart and clean the glue off the blend door and replaced the cables. The problem I have now is the...
May 14, 2025
Got the compressor replaced. STILL no cold air. The radiator fan connector started smoking when I tried to have the system filled...fan...
May 14, 2025
Need help with stereo speaker wiring
Turns out my problem this entire time was the radio box itself. Had NOTHING to do with the new speakers. Apparently Ford's crappy radio...
May 14, 2025
matayo47
p0016
I'm at a loss rn. I've got a 2011 1.6L with a p0016 code. I bought the car from someone who had timing issues with it. originally when I...
May 13, 2025
Nicks
Key not detected
Hi. I have a 2016 eco boost. I have just replaced the plastic parts of the key fob and put the little circuit board in top half of the...
May 13, 2025
LionsTooth
Welcome!
May 12, 2025
LionsTooth
JoeBob's post
Hello. I recently purchased a 2018 Fiesta SE. Bought it after my 1991 Geo Metro's transmission went to hell in a handbasket. And...
May 12, 2025
velton
Noisy Exhaust
Recently I had to replace the rear silencer on my Fiesta. The garage fitted a Motorcraft one but it is extremely noisy. Has anyone had a...
May 12, 2025
Rear bumper cover rivet size?
The rivets on the rear bumper cover mounting brackets and the impact absorber are what appears to be aluminum. I just don't know what...
May 11, 2025
Try here to help you - LASCO - they are a local supplier around my area - they may be able to supply or at least identify - what you...
May 11, 2025
If you visit the Ford dealership parts department they will be able to fix you up with the proper size rivits. They aren’t for the...
May 11, 2025
From that diagram, it looks like Ford doesn't even have the #9 rivet in its list, if that's even what I need argh!! I guess I'm gonna...
May 11, 2025
