Bazza
AC blower not blowing out of interior vents on windshield vent
Hi, I had the same problem last week. It's to do with the actuators. There might be up to 3 of them, I was dreading it to be behind the...
May 23, 2025
New to Us 2014 Fiesta -Is there Warranty on the Characteristic Transmission Shuddering?
The transmission is an "automatic." It shifts itself. The problem is that it doesn't have a torque converter. It shifts gears using a...
May 22, 2025
Functinal air vents
You can reference the pro rally Fiesta’s for the best location for ducted vents on the hood. These pieces are available from several...
May 22, 2025
CoJack's post
2016 Fiesta SFE
This is the SFE hatchback 4 door. Red, black interior. Essentially an SE with the 1.0 Ecoboost 3 cylinder engine and a 5 speed manual...
May 22, 2025
Bilstein B6 struts and shocks. If you are installing them, post impressions and questions here....
The rear springs are bolt on. The front springs require a spring compressor. If you’re not comfortable using them, you can unbolt the...
May 22, 2025
Are 2014 Fiesta Transmissions THAT bad?
The automatic dual clutch transmissions are junk. Ford put them out without thinking about long term reliability. It ended up costing...
May 22, 2025
damian5000
Have seen a few threads crapping all over them. Are they that bad?
May 21, 2025
damian5000
What does this mean "shift it with throttle input"
May 21, 2025
HPMotors
New Member but long time Mk1 owner.
Old timer here in the US with a 1979 Fiesta that I've had a while. Last Sunday, I was out behind my barn and saw my poor Fiesta. Been...
May 21, 2025
CoJack
2016 Fiesta SFE
May 20, 2025
renz
U0401 Error in my Ford Fiesta S 1.6 2012
I watched the mechanic remove the fuel pump, which is located under the backseat. He twisted off the metal ring covering the fuel tank...
May 20, 2025
renz
It's the P0351 - are the plug wires ok? The process to even detect this code requires a misfire - but the way it can detect this is...
May 18, 2025
renz
The mechanic checked the high-tension wires and said they are still fine. I just had the fuel pump strainer replaced and cleaned the...
May 18, 2025
Paramedicdaniel
Strange Transmission issue
Ford Fusion Maintenance, Warranty Issues & Trouble
Hey all. I am attempting to help a friend out with his fusion. It’s a 2012 with the 3.0L. The issue is when you first cold crank the car...
May 18, 2025
Jeanie McVay
Michelin Pilot 4
I put Michelin tires on my 2023 and a much smoother quite ride. MPG average about 22mpg but where I live a lot of stop lights / 4 way...
May 18, 2025
