ggrinstead
B3NN3TT's post
Knocking sound while turning (mostly right turns)
This can be a symptom of a failing CV joint in your axle. That would be my first target.
May 30, 2025
ggrinstead
Stuttering when cold
My 2022 Edge does this also. Unfortunately I don't have the option to disconnect my battery for 5 weeks.
May 30, 2025
ggrinstead
Edge sport
Both good.
May 30, 2025
ggrinstead
Engine surge
Has anyone had a problem with the engine surging or what feel like missing? On acceleration the engine seems like it misses a lot. When...
May 30, 2025
ketchup_burgers
Cup holders
My 40 oz. Stanley fits perfectly into the driver's door cupholder. No, it does not affect the audio from the speaker. This will keep...
May 30, 2025
ketchup_burgers
Ford IDS & VCI Incompatibility? 2011 Fiesta SE
IDS - Integrated Diagnostic System VCI - Vehicle Communication Interface Hello all, I'm hoping to DIY an ABS Module replacement. I've...
May 29, 2025
hdaniel85
System Off to Save Battery Message - is this normal?
I just started having this issue the past month, 2022 ST, I will go ahead and get the battery replaced (49k miles on it) and do the BMS...
May 27, 2025
snowman
2014 Focus issues
Try replacing the crankshaft position sensor
May 27, 2025
snowman
Stop start system, not stopping anymore.
Typically any voltage below 10 is failing.
May 27, 2025
pompeyrodney
Thanks for the suggestion but I would rather know what the "certain level" of voltage should be in order that I can test the battery first.
May 27, 2025
snowman
Please help!
Depending on how hard you hit the curb, it could be that the fuel cutoff switch needs to be reset. In the U.S., it’s located on the...
May 27, 2025
snowman
I would start with replacing the battery. Most time if the battery voltage is below a certain level it'll prevent the auto start/stop...
May 27, 2025
pompeyrodney
Third Generation Focus
For the last few months my stop start system has ceased to function. For a short while whilst it was still working I was getting a...
May 27, 2025
Tom
Newby Intro
Welcome aboard!
May 27, 2025
pompeyrodney
Newby Intro
Hi, I am the owner of a 2014 Focus 1.6 Econetic, that I have owned since 2017. It now has some 116,000 miles on the clock. I am hoping...
May 27, 2025
