ronmac1117
99bledsoe's post
2007 ford focus ses lots of issues
Bought a 2007 Ford Focus SES it was hit in front and I think there's a bad hood pin sensor or bad wire now remote start doesn't work...
May 31, 2025
ronmac1117
2007 Focus Exhaust Manifold
I changed engines and convertor is stopped up, what , what catalytis convertor will fit witout spending arm and leg for a new one
May 31, 2025
ronmac1117
2007 focus SE A/C
2007 focus SE A/C works at times, not all time, changed motors and fails to operate properlu
May 31, 2025
itz_Lee
Ford fiesta 2005 model 1.25 petrol rocker cover gasket
Ford Fiesta Ordering
Hello I’m a new member to this form and I was wondering if anyone could help me with rocker cover gasket that would fit my 54 plate fiesta
May 31, 2025
Ale-gawl
2011 Ford Fiesta 1.4tdci No Start
Hi, I’m trying to fix a non-start issue on a 2011 Ford Fiesta 1.4tdci. I’m hoping there’s some experts on here which can help. There is...
May 31, 2025
Ford IDS & VCI Incompatibility? 2011 Fiesta SE
You are blazing a new trail with this! You probably need to make sure that your computer is running on the newest version, 24H2 update...
May 31, 2025
ggrinstead
B3NN3TT's post
Knocking sound while turning (mostly right turns)
This can be a symptom of a failing CV joint in your axle. That would be my first target.
May 30, 2025
ggrinstead
Stuttering when cold
My 2022 Edge does this also. Unfortunately I don't have the option to disconnect my battery for 5 weeks.
May 30, 2025
ggrinstead
Edge sport
Both good.
May 30, 2025
ggrinstead
Engine surge
Has anyone had a problem with the engine surging or what feel like missing? On acceleration the engine seems like it misses a lot. When...
May 30, 2025
ketchup_burgers
Cup holders
My 40 oz. Stanley fits perfectly into the driver's door cupholder. No, it does not affect the audio from the speaker. This will keep...
May 30, 2025
ketchup_burgers
IDS - Integrated Diagnostic System VCI - Vehicle Communication Interface Hello all, I'm hoping to DIY an ABS Module replacement. I've...
May 29, 2025
hdaniel85
System Off to Save Battery Message - is this normal?
I just started having this issue the past month, 2022 ST, I will go ahead and get the battery replaced (49k miles on it) and do the BMS...
May 27, 2025
snowman
2014 Focus issues
Try replacing the crankshaft position sensor
May 27, 2025
snowman
Stop start system, not stopping anymore.
Typically any voltage below 10 is failing.
May 27, 2025
