guruabyss
Blue Wire that Powers Windows
Hello, I came across this after my windows stopped working in my Ford Edge 2014. I tried to solder the broken metal connector but...
Jun 21, 2025
Replacing rear bumper cover
I no longer have the bumper cover that was destroyed when I was hit. I have no idea what SFE is. I figured out how they go on. But not...
Jun 21, 2025
You should compare the mounting holes between the original and the replacement bumper covers. I think that the SFE cover might be...
Jun 21, 2025
Exterior Cosmetic & Lighting Modifications
I got a replacement rear bumper cover, but took the moldings off the bottom and now cannot remember how the side pieces go back on...
Jun 21, 2025
Transmission Problems on 2015 Ford Fiesta
Once you have identified the actuator it should be fairly straightforward to remove it. This image I found on Google shows the actuators...
Jun 21, 2025
BananaRama
Thanks for the reply! I just disconnected the radio fuse, but the radio just keeps playing. I am assuming it is not supposed to do that...
Jun 21, 2025
Der Trommler
Hello from Bulgaria.
Welcome!
Jun 19, 2025
KYB Excel G front strut and rear shock assembly…
Giving this thread a bump.
Jun 19, 2025
Koni STR.T shock and strut discussion.....
Jun 19, 2025
Doorpro
2015 Ford Edge Oil Pan Leaking
UPDATE! I finally found a great Ford Dealership not far from home "Ford of Long Beach" who not only told me the whole story of the...
Jun 19, 2025
Doorpro
Tina, I'm sure that by now you have the issue fixed but if not, you should read my latest post. I have had the same issue for years...
Jun 19, 2025
Doorpro
Oil Pan Issues
Jun 19, 2025
BananaRama
Upon further trouble shooting it seems like I can also turn on the radio with the key removed from the ignition. Seems like it does not...
Jun 19, 2025
BananaRama
Hi everyone, For the past few weeks my Ford Fiesta has a parasitic drain issue, causing the battery to die after about a day of idling...
Jun 19, 2025
Der Trommler
Missing vacuum part.
This forum is primarily focused on the 2011 to 2019 North American Fiesta. The odds of one of our members having a prior to 2011 Fiesta...
Jun 18, 2025
