cosmicsqualor's post
Hi all! New member here! Joining this community/forum as an owner of a 2013 Ford Fiesta SE Hatchback! (Have had it just over a year now...
Jun 22, 2025
BamaRoss
Transmission Problems on 2015 Ford Fiesta
Thanks for the reply. Ended up having to first pull out the air filter box to even be able to see the transmission. From that point it...
Jun 22, 2025
cosmicsqualor
Jun 22, 2025
cosmicsqualor
MKVIIST's post
Welcome to the Ford Fiesta Forum. Please take a moment and introduce yourself, tell us what you currently drive or just say...
Jun 22, 2025
BananaRama
You have TWO radio fuses - one for "keep alive" while the ignition is off, then another for when you power the audio amplifier - which...
Jun 22, 2025
guruabyss
Blue Wire that Powers Windows
Hello, I came across this after my windows stopped working in my Ford Edge 2014. I tried to solder the broken metal connector but...
Jun 21, 2025
Replacing rear bumper cover
I no longer have the bumper cover that was destroyed when I was hit. I have no idea what SFE is. I figured out how they go on. But not...
Jun 21, 2025
You should compare the mounting holes between the original and the replacement bumper covers. I think that the SFE cover might be...
Jun 21, 2025
Exterior Cosmetic & Lighting Modifications
I got a replacement rear bumper cover, but took the moldings off the bottom and now cannot remember how the side pieces go back on...
Jun 21, 2025
Once you have identified the actuator it should be fairly straightforward to remove it. This image I found on Google shows the actuators...
Jun 21, 2025
BananaRama
Thanks for the reply! I just disconnected the radio fuse, but the radio just keeps playing. I am assuming it is not supposed to do that...
Jun 21, 2025
Der Trommler
Hello from Bulgaria.
Welcome!
Jun 19, 2025
KYB Excel G front strut and rear shock assembly…
Giving this thread a bump.
Jun 19, 2025
Koni STR.T shock and strut discussion.....
Jun 19, 2025
Doorpro
2015 Ford Edge Oil Pan Leaking
UPDATE! I finally found a great Ford Dealership not far from home "Ford of Long Beach" who not only told me the whole story of the...
Jun 19, 2025
