ijerez
Sagging rear - Airlift 1000 system versus stiffer coils and Bilstien B6.
Thanks for replying! I'm going to have to limit the tough weight. I had to add a riser to my tow hitch to keep the cargo carrier from...
Jun 26, 2025
ijerez
Thanks for the reply Thank for the reply! I'll purchase the airlift bags first and install. I've got camping trip coming up and the...
Jun 26, 2025
ijerez
You are not alone in wondering how a system like this could be used for load leveling on a Fiesta. I live pretty close to the Airlift...
Jun 26, 2025
Have you changed your cabin filter?
Jun 26, 2025
1.6 SOHC or SOHC?
So you know, ANY motor that had bad timing or jumped time - are subject to be called interference due to Head-to-Valve-to-Piston...
Jun 26, 2025
gfh77665's post
Checking in at 90K miles... The Fiesta performs flawlessly. I drive it anywhere any time with full confidence. The trim still is a bit...
Jun 26, 2025
Restricted evaporator air flow and/or running low on refrigerant can cause the evaporator to ice over. There's an evaporator temp...
Jun 26, 2025
01jaguar
Random Electricial issue (May be related to onboard RV Tow package)
So the issue was the negative battery cable? I'm having similar issues, but my battery also drains within 1 day. If I jump start car and...
Jun 26, 2025
01jaguar
Jun 26, 2025
Cvs20 purge solenoid
hey Andy I did not have C.E.L , as I deleted that code when the pcm was flashed and it was actually a dirty filler neck mouth ,had...
Jun 26, 2025
jljbtm
Looking at a 2019 for my daughter.
We had a 2016 with 105,000 miles and no problems at all and liked it so much we just bought another one 2024
Jun 26, 2025
jljbtm
Brake grinding noise
We have a new 2024 Ford Edge our 1st one was a 2016 and it was the best car (i called it Fords hidden Gem) well we turned it in at...
Jun 26, 2025
Replacing rear bumper cover
Ok, thanks
Jun 26, 2025
You should connect a voltmeter to the battery and then start pulling out fuses starting with the audio system and then the anti theft...
Jun 26, 2025
You can see if you have something different by going to an online ford parts website and inputting your vin number to bring up an...
Jun 26, 2025
