gfh77665
Radiator - A/C spotlessly clean. We get lots of rain so almost no dust. That, and I car wash spray the random dead bugs off...
Jul 1, 2025
gfh77665
Remember to keep the radiator and AC condenser clean so air flows thru - the Oil loss may be due to thinning and burn off from the PCV...
Jul 1, 2025
Front lower control arm, performance oriented bushing upgrade.
Giving this one a bump simply because of the ball joint installation part of the thread.
Jul 1, 2025
Nicholas123
Wondering if there is a common cause of the combination of these troube codes.
Greetings, My 2013 Fiesta has been off the road for a year. Just put a new battery in it and using a good trouble code reader, we've...
Jul 1, 2025
Gear cable routing 2006 fiesta 1.6 duratec
You could also have a worn out bushing at the point where the shifter cables attach to the transaxle. There shouldn’t be any play or...
Jul 1, 2025
Caitlin2004
Replacing rear light harness on ford fiesta style climate 2008
Hello everyone, Trying to replace a wiring harness on my ford. Wondering if anyone is able to help on doing it as cant find anything on...
Jul 1, 2025
Replace Ball Joint
I knocked out the ball joints with a hammer and a block of wood. The Delco ball joints I bought had the circlip retaining clips and they...
Jul 1, 2025
WarrenFord
Good day fine people. Recently acquired a 2006 1.6 2 door fiesta. RHD. Awesome vehicle, but having some gear problems. 5th gear selects...
Jul 1, 2025
borgward's post
Replace Ball Joint
Reason I ask is that I saw videos of them being pressed out but that those had circlip retainers that had to be removed before pressing...
Jun 30, 2025
Along with all those great suggestions - did you also check to see if the evaporator - being in the passenger compartment - it's...
Jun 30, 2025
How many miles do you want out of your Fiesta, realistically?
I have an ST, which you can see. My #1 fear is rust. This car has run flawlessly since I bought it with 115 miles on it. It's a Fiesta...
Jun 30, 2025
Wytt H's post
I did that recently, and the idle has gotten a lot better, but has not completely gone away. There's still a bit of vibration and I...
Jun 30, 2025
Replace Ball Joint
Jun 30, 2025
Replace Ball Joint
Yes. They are pressed in. It’s a lot cheaper to replace the ball joint than to replace the arm assembly
Jun 30, 2025
Replace Ball Joint
2013 Fiesta SE hatch. The ball joints are not held in place with circlips. Can they be pressed out?
Jun 30, 2025
