Replace iB/5 input shaft Seal
Thanks but that's for the ST's 6 speed manual transmission. The SE has a 5 speed iB/5 manual transmission. Has entirely different seal.
Jul 4, 2025
2013 Fiesta SE Hatch 5 1.6 5 speed manual. Installing used transmission. Already replaced the half shaft seals. How to I remove the...
Jul 3, 2025
Fiestaparty
Adding a circuit or two
Thanks for your ideas. I am nervous about using a circuit with more than a little current on it, even though my guess is my 2 circuits...
Jul 2, 2025
Barberryn's post
Starts well but sets "service engine" information and powers down engine upon shifting into 1st.
Found my throttle pedal and oil service reset issue - a mouse nest and two throttle pedal wires chewed apart. I used help from here to...
Jul 2, 2025
Barberryn
Jul 2, 2025
no spark
Examine the sections of the harness that you “cut down” . Are there any ground connections that you removed. Or, did you perhaps not...
Jul 2, 2025
I would tap into the wiper circuit to power the dash cam using a “tap a circuit “ fused connector. If the other circuit is going to be...
Jul 2, 2025
Fiestaparty
Hello, I have 2 circuits that I want to add to the car. 1. for the dash cam. It is currently in the cigarette lighter which is always...
Jul 1, 2025
Cjmac
2011 se long cranking time
Good afternoon, new here. I've been having this issue for a couple of months where every once in a while after it sits for a day or...
Jul 1, 2025
Tiki Dave
Radiator Fan Only Working On Low Speed
Hi. I had my air con re-gassed along with a new compressor a couple of days ago. It works great now but the shop told me that my...
Jul 1, 2025
gfh77665
How many miles do you want out of your Fiesta, realistically?
I have an ST, which you can see. My #1 fear is rust. This car has run flawlessly since I bought it with 115 miles on it. It's a Fiesta...
Jul 1, 2025
gfh77665
Radiator - A/C spotlessly clean. We get lots of rain so almost no dust. That, and I car wash spray the random dead bugs off...
Jul 1, 2025
gfh77665
Remember to keep the radiator and AC condenser clean so air flows thru - the Oil loss may be due to thinning and burn off from the PCV...
Jul 1, 2025
Front lower control arm, performance oriented bushing upgrade.
Giving this one a bump simply because of the ball joint installation part of the thread.
Jul 1, 2025
Nicholas123
Wondering if there is a common cause of the combination of these troube codes.
Greetings, My 2013 Fiesta has been off the road for a year. Just put a new battery in it and using a good trouble code reader, we've...
Jul 1, 2025
