2013 Fiesta blower motor (power to relay coil)
The line from the Blower Relay to the BCM or to the Controller (More than likely the controller) - you'll need to do a continuity check...
Jul 6, 2025
Hello. My friend has a 2013 Fiesta. The blower motor recently quit working. As time and weather permits (seems it’s rained all summer so...
Jul 6, 2025
Replace iB/5 input shaft Seal
I will be installing YS4Z-7048-AA in the used transmission. See pictures. Has no spring. The flat side is installed toward the inside of...
Jul 6, 2025
DannyDee2
Happy 4th of July
Happy 4th of July
Jul 5, 2025
trishtemp
2014 Fiesta SE need tranny advice
We bought a 2014 Ford Fiesta SE from the city. about a year ago. It was a fleet vehicle with 45,000 miles on it. Our 19 year old...
Jul 5, 2025
Thanks but that's for the ST's 6 speed manual transmission. The SE has a 5 speed iB/5 manual transmission. Has entirely different seal.
Jul 4, 2025
2013 Fiesta SE Hatch 5 1.6 5 speed manual. Installing used transmission. Already replaced the half shaft seals. How to I remove the...
Jul 3, 2025
Fiestaparty
Adding a circuit or two
Thanks for your ideas. I am nervous about using a circuit with more than a little current on it, even though my guess is my 2 circuits...
Jul 2, 2025
Barberryn's post
Starts well but sets "service engine" information and powers down engine upon shifting into 1st.
Found my throttle pedal and oil service reset issue - a mouse nest and two throttle pedal wires chewed apart. I used help from here to...
Jul 2, 2025
Barberryn
Jul 2, 2025
no spark
Examine the sections of the harness that you “cut down” . Are there any ground connections that you removed. Or, did you perhaps not...
Jul 2, 2025
I would tap into the wiper circuit to power the dash cam using a “tap a circuit “ fused connector. If the other circuit is going to be...
Jul 2, 2025
Fiestaparty
Hello, I have 2 circuits that I want to add to the car. 1. for the dash cam. It is currently in the cigarette lighter which is always...
Jul 1, 2025
Cjmac
2011 se long cranking time
Good afternoon, new here. I've been having this issue for a couple of months where every once in a while after it sits for a day or...
Jul 1, 2025
Tiki Dave
Radiator Fan Only Working On Low Speed
Hi. I had my air con re-gassed along with a new compressor a couple of days ago. It works great now but the shop told me that my...
Jul 1, 2025
