Mathew36963
14 Fiesta SE hatchback. Won't start.
Okay my vehicle is a 2014 Ford fiesta se hatchback 1.6 l. kay so let me start off by saying as I would drive around town occasionally...
Jul 21, 2025
Head gasket likely shot, engine replacement tips?
The engine block and the head need to be checked for warpage - else you may not be able to reassemble it right once the new gasket of...
Jul 21, 2025
Engine is out. It’s in the garage, which is normally the home of my show car. Took me 12 hours yesterday, about typical. Hood stayed in...
Jul 20, 2025
BananaRama
So I managed to fix the issue, but I am not 100% sure which one of the following was the cause: 1. I replaced the radio with a carplay...
Jul 19, 2025
SpeedyG!
Blend door issue
I've got the climate control picture on the left. Ended up buying a motocraft actuator and will give that a shot. I have small hands and...
Jul 17, 2025
SpeedyG!
Blend door issue
IF the Drum turns freely, and you can move that gear on the drum the actuator controls BY HAND to make it blow air out of those...
Jul 17, 2025
SpeedyG!
where is the fuse for the interior lights?
I had yanked all the fuses behind the glove box and nothing happened. But anyway was able to work on the car without the battery dying...
Jul 17, 2025
SpeedyG!
Blend door issue
Followed your instructions and I only get air coming out the defrost now. when I change the settings to passenger vents nothing happens...
Jul 16, 2025
SpeedyG!
Found a fuse diagram for my 2015 fiesta. says it's the #26 20 amp fuse in the engine compartment, yanked it, and my interior lights are...
Jul 16, 2025
SpeedyG!
Blend door issue
Thanks for responding. saw the other post. will give it a shot
Jul 16, 2025
Geeshik
03 ZX5 rear suspension hardware?
I received the hardware and parts I ordered. I was going to start on the job tonight but found the rear K-member rotted out where the...
Jul 15, 2025
SpeedyG!
Blend door issue
Hello all, yesterday driving home during rain, windows were fogging up. turned on the defrost and noticed I was getting air through the...
Jul 15, 2025
Pamzus
Tent camping with a Fiesta..
Very impressive!!! Thanks for sharing your setup with the Fiesta community.
Jul 15, 2025
miguel1911
Drive until engine failure
Hello all . Awhile back I received a letter from Ford informing me about replacing the timing belt and related parts because of timing...
Jul 14, 2025
DiabloVerde
Vibration linked to radiator fan
Jul 13, 2025
