MarcelE
And again a newbie
Sure, i will.
Aug 8, 2025
Fooldancing
ADVICE NEEDED: 2011 Fiesta SE hatchback heater blower
It is a 5spd manual. When the original engine cooling fan burnt up it took the plug with it. I got an aftermarket plug that was OEM...
Aug 7, 2025
CRZN427
Another Newbee
Up Date... After my last OBD-II scan, and some on line searching, I found that the vapor canister purge valve was the most likely...
Aug 7, 2025
MarcelE
And again a newbie
Ah Okay!!! This is the US forum. My bad, don't know why, but i thought it was the UK version. Anyhow, i already gained some interesting...
Aug 7, 2025
Fooldancing
I have a 2011 Fiesta SE hatchback. The engine cooling fan motor burnt up and fried the plug that plugs into it. My nephew and I...
Aug 6, 2025
frustratedfiestaowner
Advice sought - High oil consumption and Turbo issue.
My partners Ford Fiesta 2017 1.0 threw up a "service engine soon" light, she booked it into the garage and when they checked it over...
Aug 6, 2025
Head gasket likely shot, engine replacement tips?
Good thing about the coolant, thanks I didn’t know that. The crank pulley is on good and solid and square. I got the crank bolt loose...
Aug 5, 2025
So you know, the oil pump is at the crank, base of Cylinder 1 - make sure they didn't smack the harmonic balancer out of true and it now...
Aug 5, 2025
Ivu04
Airbag light after removing seats ;(
Hello fellow fiesta owners. I have the 2013 pre facelift kinetic fiesta with airbags on the seats. I get error codes B0001 and B0010 in...
Aug 5, 2025
Fiesta poor downshift to 1st
Yeah that cable system makes me wonder. What's next, 5 on the tree? My last generation 99 Escort 5 speed has a proper mechanical...
Aug 5, 2025
The only issues I have ever had with the IB5 is output shaft seal leakage. Seals are a 50 to 60 k maintenance item as far as I’m...
Aug 5, 2025
My Fiesta was built 4/17/2023. Of course the transmission could have been built on an earlier day. The sticker w/barcode on the the...
Aug 4, 2025
Buggyfever2276
2.4 m/t bogs then eventually reves
Ford Fusion First Generation
06 Ford Fusion 2.4 L duratec SE manual transmission that I just picked up I had to put a clutch in it so I pulled the motor ended up...
Aug 4, 2025
I got the local engine yesterday. Local is 1.5-2 hours away. Had to get up early on my day off, and was too tired to accomplish anything...
Aug 3, 2025
I wonder if too much fluid was installed at the factory causing the IB/5 hard to downshift to 1st. Other things were not right. Took...
Aug 3, 2025
