Fiesta poor downshift to 1st
I don't know much about transmission ,but you could try these...
Aug 21, 2025
You don't - not with what is stored in the PCM as to what to work with in engine RPM and gear speeds - only inputs are from the speed...
Aug 21, 2025
E
Ecobooster
Engine rebuild
thanks
Aug 20, 2025
RockySES
Anybody try this tire?
Ford EcoSport Wheels & Tires
Hello I wanted to ask if anybody has any input on this tire on the Ecosport. I currently have a 2021 2.0L SES 4wd with the factory...
Aug 19, 2025
weedog
D3 relay fuse
How do you get the D3 relay fuse for a/c clutch out of fuse box
Aug 19, 2025
And again a newbie
Welcome! I hope you get that issue settled.
Aug 19, 2025
Advice sought - High oil consumption and Turbo issue.
There was a recall on those engines in the US for the Ecosport and Focus, but not for the Fiesta. I would try to find out if there's a...
Aug 19, 2025
Vision 425 Bane Gunmetal Wheel with Painted Finish in15"
Hello fiesta world been a time , but hopefully i can be back more often is been crazy couple months and after 10 years working for...
Aug 18, 2025
Head gasket likely shot, engine replacement tips?
Well looks like we are good for now! I put the engine in over the weekend. Filled it up and cracked the radiator vent many times just to...
Aug 18, 2025
The 1.0 has many issues. Google “ford 1.0 Ecoboost engine problems”. There is nothing I can add to provide you with much comfort or advice.
Aug 18, 2025
WHERE TO BUY PARTS
I would strongly suggest that you get Ford original parts for your timing belt replacement. While you have it apart do the water pump...
Aug 18, 2025
Aftermarket exhaust on N/A 1.6
You can install the ST exhaust system from the converter back. You should check facebook marketplace to see if someone is selling their...
Aug 18, 2025
Engine rebuild
No.
Aug 18, 2025
Maranda98
Possible Transmission Issues
Hello, my 2019 Ford Fiesta SE has been having some issues with the RPMs revving up but not accelerating. This is an automatic, I am...
Aug 18, 2025
Sampled the fluid I drained. Will send to Blackstone for analysis.
Aug 17, 2025
