WebbedZ
No hot air from AC
@Handy Andy @econoboxrocks So update from earlier I saw on some other forums to try max fan and bits but this didn't work although when...
Sep 14, 2025
No hot air from AC
The fan shouldn't be loud. Whoever replaced the radiator may have messed something up. I'd start with the fan and go from there.
Sep 13, 2025
WebbedZ
No hot air from AC
I've recently bought a Fiesta that has sat for a while and previous owner apparently never used AC. I've gotten the system regassed, the...
Sep 13, 2025
JRR
Stalling,
Engine Performance
Engine runs sweet on tic/over ,but stalls after revving ,no power there when driving once covered a couple of miles.Checked all obvious...
Sep 12, 2025
Maccam67
2013 3.5L Smoke Test on Brake Boosters
Smoke introduced via the vacuum hose,after the map sensor, directly into booster, and smoke expels from throttle body. Does this...
Sep 12, 2025
fordracinjunkie
Power steering issues
I have 2002 Focus everything was working fine. Car set for 3 days I started it smoke came from under the hood. Smoke was coming from...
Sep 10, 2025
ijustwuna
Help, interior light
I tried to change my interior light to an LED today and there was a spark. It now doesn’t work, even with the old bulb. I can’t find the...
Sep 10, 2025
manbearpig's post
Manbearpig's 2019 Fiesta SE sedan
Finally found the sport pedal covers I wanted... Original battery took a crap, went to the dealer and got a new one, along with a new...
Sep 10, 2025
ClawHammer
2018 Fiesta SYNC APIM help
Just tried removing the fuse. Fuse 17 was definitely the one. Left it out about 30 minutes and no change. Thought it would've wiped...
Sep 9, 2025
ClawHammer
Hi, My son's 2018 Fiesta should have Apple CarPlay but this has stopped working. Ford had a look when it went in for an MOT. They said...
Sep 9, 2025
Phil Blake
Pair of boxed Headlamps
During the 1980s we owned a number of Fiestas. I have recently found 2 boxed headlights in their original boxes and packaging for a...
Sep 9, 2025
korisnik
Ambient temperature sensor reading too high
Hi everyone, I have a 2009 Ford Fiesta. Recently, I programmed the trip computer and installed a new ambient temperature sensor...
Sep 8, 2025
Naturana
Powershift.When change oil?
привет! и спасибо за совет. а когда менять жидкость в Piwershift?
Sep 8, 2025
The Powershift transmission is a dry clutch type of automated manual transmission. The best way to ensure a good lifespan is to drive...
Sep 8, 2025
Naturana
Если problem нет, менять не стоит. Независимые мастерские советуют поменять. Но я читал, что в некоторых автомобилях проблемы начинаются...
Sep 8, 2025
