Michael_Mikey_Mike
Looking for the PCV valve on my 2015 Fiesta S
Thanks for the explanation on why I've seen some differing info on this motor. In the past couple of days, I've realized some of this...
Oct 12, 2025
Michael_Mikey_Mike
The PCV valve was replaceable on earlier UK models of the Fiesta - until about 2009 - then they changed the motor from a Ztec to a Sigma...
Oct 12, 2025
Ktrout
2020 fusion low oil pressure
I have a low oil pressure light that intermittently comes on. It starts when it’s at operating temperature and doesn’t always come on...
Oct 11, 2025
L8gan
Windscreen Washer Nozzles
Hi there, I had the same issue with my own. Turned out that the fluid reservoir where the washer fluid would rest was clogged, I’m...
Oct 11, 2025
2
2014FiestaHelp36963
14 Fiesta [p0301 & p0884 & p06b8 & p0607] & engine Malfun. Serv. Now. & No fuel pump prime! Please help me!
14 ford fiesta engine malfunction service now, wont start, dont hear fuel pump priming w/:p0301 & p0884 & p06b8 & p0607 So I'm not sure...
Oct 11, 2025
1
1.0Egg
Ran low on coolant, now starts rough/rough idle that mostly clears
Last night I was driving and my engine temp came close to overheating. I had a cracked coolant tank last year so I remembered its signs...
Oct 10, 2025
Michael_Mikey_Mike
Hey everyone. I'm trouble shooting a P291A code on my daughter's 2015 FIesta SE 1.6L. MAP sensor covered oil replaced that today in case...
Oct 10, 2025
KrayZJay
The primary concern with the Fiesta, or really any “modern” car or truck, is maintenance and repairs. Preventive maintenance is so...
Oct 9, 2025
KrayZJay
Dalbegay1's post
Whats good everyone. Just joined up, I drive a 2015 Ford Fiesta SE. I will do my best to help out, also look forward for help as well...
Oct 9, 2025
KrayZJay
How’s everyone doing? I bought my 2018 Fiesta ST a month ago and this is the best car I’ve ever owned hands down. It came with some mods...
Oct 9, 2025
Frustratedfiesta
2016 fiesta S. Keys now missing.... any way to bypass the anti theft key detector?
Is there any way to bypass the immobilizer that tells me that I need to have the key in the ignition to start the vehicle? I already...
Oct 9, 2025
AC not working after Starter replacement
If the Starter is OK, you may have bumped or cut the wires to the A/C clutch - check the fuses and inspect the wiring to the AC clutch -...
Oct 9, 2025
QuietOC's post
brake dust shield/ backing plate front left
Sorry, very late reply, but others may have the same dillema. I was able to order both front brake shields for my 2011 Fiesta from a...
Oct 9, 2025
Dalbegay1's post
Oct 8, 2025
mjt
Stop start system, not stopping anymore.
I have a 2015 Mondeo with Auto Start Stop and I didn't even know it was there. When I replaced a failing battery, one dead cell, so...
Oct 6, 2025
