conrad401
2019 SE (automatic) - transmission - Return of the Shuddering
About a year ago I started experiencing a worrisome issue with my Fiesta's transmission system: as I was accelerating at low speeds, in...
Jan 17, 2026
Julianj
HELP Timing issue (I think) 2015 Ford fiesta SE 1.6
I was starting to think the same thing, I didn't mess with any electrical connectors though, when I first cranked it after getting it...
Jan 17, 2026
Julianj
I have it all apart right now, I hand cranked the motor a few times and both cams on top line up perfectly. So I don't know what the...
Jan 17, 2026
Dave-2003
Got my beauty in for some work
Update on the car, what do you think of the belt ? I'm pushing for it to be done i want as much as possible done on it now while they...
Jan 17, 2026
Julianj
I recently did a water pump replacement on a 2015 Ford fiesta. The first time everything went well started right up, but the shitty...
Jan 16, 2026
ImprezaST
Sync Software version 4.7
2011 Fiesta SES manual hatch, came with CR3T-14D544-BC DE8T-14D544-AD zip from Ford...
Jan 15, 2026
izzyespinoza1999
2012 se Stalling at red lights
Take a look around the outlet of the tailpipe. IT should be dark color - similar to "Kingsford charcoal" but not greasy - if greasy-...
Jan 15, 2026
Dave-2003
Got my little beauty in for some essentials, should be running sweet when I get her back 😁 wet belt, water pump, turbo and carbon clear...
Jan 14, 2026
ZeroDarkForce
Transmission is suddenly acting funky.
So I ended up getting a check engine light and I took it too the dealer. The transmission has given out. Clutch replacement, actuators...
Jan 14, 2026
Skipzag
P0504
I just installed a new blower motor and now have p0504 code. Brake lights are working. Any suggestions would be awesome thank you
Jan 13, 2026
Skipzag
P0504
Replaced blower motor. What a pain! Now have p0504 code. Wtf. Brake switches are plugged in and brake lights are working. Any...
Jan 13, 2026
RichManWatts
Ford Fiesta 2013 1.6 TDci engine
I am looking for a Ford Fiesta 2013 1.6 TDci engine - code: tzja - 083 325 5963
Jan 13, 2026
Senne
Tuning MK8 Fiesta ST high Milage
Performance Tuning
Hello everyone, I'm new in this community. I wonder if it's safe to tune the MK8 Fiesta ST 1.5 with higher milage 78.000 miles or...
Jan 12, 2026
Nktidwel
Headlights
Cool, then I won't try cheaping out by getting the 2014+ style. I wouldn't mind the styling change if it physically bolted up and didn't...
Jan 11, 2026
DrLightman
Air vents only blowing at windshield
Near the gas pedal there is a little motor with a lever and a plastic white arm that rotates and change the air direction between...
Jan 10, 2026
