Bucsfan94
New start stop issue
I have a 2023 ford edge, the issue I am experiencing is even though I turn the start/stop off in the vehicle settings it continues to do...
Mar 11, 2026
Bucsfan94
Start stop issue
Mar 10, 2026
I just recently re-did work that a dealership did 3-years ago. CV Axle work they did, but that is a long story for later - I hope to be...
Mar 10, 2026
imba
Resetting PATS System on 2012 Fiesta
Having an issue with the anti-theft system on our 2012 Fiesta. Wouldn't start one day so I thought maybe the key was dead. Started up...
Mar 9, 2026
Baket
Picked up a 2014 edge
hey everyone me and my family picked up a 2014 ford edge limited and well everithing seems fine but I'll like to get some advice fo the...
Mar 9, 2026
bdodkin
Mk 4 Fiesta 1.25 professionally converted with 1.7 puma engine/gearbox plus necessary upgrades
I will be selling this car (correctly DVLA registered) Any ideas of value? Always garaged, rarely used but properly serviced and...
Mar 9, 2026
Actually, next up will be changing out the struts and doing the brakes. New rotors, pads, drums and shoes. I'll be doing the front...
Mar 7, 2026
Beachbum37
2017 Ford Edge SEL xenon headlight upgrade
Mine is a 2016 SEL that shares your headlight problem. Maybe the access issue got fixed in 2017? I doubt it. So I just spent four...
Mar 6, 2026
FatBeardFishing
Fan Clutch Help
I have a 98' Ranger 4.0 I scored for $500 as a project. What direction should I be turning the fan clutch nut to remove. From the looks...
Mar 5, 2026
Ragz
2011 fiesta transmission problems
Thank you . I’ll check into that
Mar 4, 2026
ken pecora
2010 sport trans
Ford Fusion First Generation
2010 fusion sport with 120k miles. Car runs and shifts fine. Trans has never been serviced. Some people recommend draining and replacing...
Mar 4, 2026
RosieRumble
Ford Fiesta 2014 - Drivers Side Window/Light Fault
"Under the dash" - you can help that by removing those plastic covers on the floor side kick-panels to expose the wiring connectors -...
Mar 2, 2026
RosieRumble
Almost unbelievable, but here I am again - nearly a year later! 😅 Last year I had an auto electrician look at my car because of ongoing...
Mar 2, 2026
Ragz
Hey guys I have a 2011 Ford fiesta with a ib5 manual transmission. The transmission started making a grinding noise. I decided to drop...
Mar 1, 2026
Got the evap canister purge valve replaced last night and that finally allowed me to clear out the code. Car is back to more confident...
Feb 28, 2026
