Bigjakester
Stalling issue, questions about data points
2012 ford fiesta 1.6l NA Manual Only fault code is P0627 Engine stalls/dies only when going 40-60 mph, low RPM, little or moderate...
Apr 11, 2026
Lots of trouble codes, car runs fine
Hi. The car has been running fine after I completed that engine swap last summer. Occasional engine light, which was always MAF. Cleaned...
Apr 10, 2026
Glad you're alright and hope replacing wiper blades doesn't put you in traction at the local hospital - wish you the best and glad to...
Apr 10, 2026
Lexbll
Front noise problem
Hi, thanks for the reply. I bought the car, but since it had been sitting in the garage for a while, I thought I'd replace both the...
Apr 10, 2026
Lexbll
Front noise problem
Wheels, Tires, Chasis, Brakes & Suspension
Good morning, i have a ford fiesta mk7 1.25 82hp 2009, I bought it in September 2025 used with 25,000 miles, it did very few miles a...
Apr 10, 2026
Lexbll
Hi everyone
Good morning, let me introduce myself briefly, I'm writing from Italy and I own a ford fiesta mk7 1.25 82hp 2009
Apr 10, 2026
New struts are in. As well as sway bar links. The old strut bearings were shot. Really loose and probably where a bunch of my rattling...
Apr 9, 2026
Tomorrow is another attempt at removal of those 18mm nuts that hold the struts to the knuckles. A few weeks ago, I made an attempt and...
Apr 8, 2026
dmustang2
SyntheticAtmosphere's post
How many Ford Fiesta owners in the USA have reached 150,000 miles?
OP, If the pump is working properly I would run it. However, I would consider replacing the fuel pump sock if it is serviceable. Your...
Apr 8, 2026
dmustang2
2014 Fiesta S. Very noticeable noise.
So I have a very irritating noise coming from the right of the car. It's a rattling of some sort. I've check the rear shocks, not the...
Apr 8, 2026
E
Edge
Ignition Lock Keyway Tiny Contact
Ford Ranger Discussions (1983β2011)
When replacing the ignition lock cylinder, a small plastic contact housing broke away from the housing cylinder. I slipped it back in...
Apr 7, 2026
Nicki in Detroit
Hi all π
Hi, good morning π
Apr 7, 2026
Nicki in Detroit
Transmission overheating HELPPPπ«¨
Third Generation Focus
2015 focus se sedan : As always every 3mon./3000miles I have a oil change and fluid/belts/hoses done.. last month the check engine...
Apr 7, 2026
Hi all π
Hello and welcome!
Apr 7, 2026
Nicki in Detroit
Hi all π
Hi all π
Apr 7, 2026
Learn moreβ¦
