WuNgUn
2015 SE Trunk Water Leak?!
I had bad tape behind tail lights and fixed the leak with some aluminum tape... That was 2 years ago. Now my interior is getting...
Apr 14, 2026
Will303
Soggy carpets
Oh boy, i do see rear-end impact damage repair. And having just sprayed the rear of the car with a hose for a few mins, water has...
Apr 14, 2026
Bigjakester
2012 1.6l NA evap issues
1. Does anyone else have a "check valve" that looks like the one pictured? Looks like a dummy check valve to me. I do not see how it...
Apr 13, 2026
JCrash
Thermostat housing-stuck bolt
Maintenance, Warranty Issues & Trouble
I was recently trying to change the thermostat out in my 2010. The bolt in the back that's hardest to get to spins but won't go up or...
Apr 13, 2026
Will303
Soggy carpets
Hi, I just bought a 2012 Fiesta and have discovered that the carpet/underlay in the driver and driver-side rear passenger footwells are...
Apr 13, 2026
I'm good, probably a little hyperbolic the other day regarding my back. Did a few PT exercises and I just had lingering muscle soreness...
Apr 12, 2026
(y)
Apr 12, 2026
Hi everyone
Ah! The Good Ol Days! Nice to see vintage vehicle owners stopping by - welcome!
Apr 11, 2026
Lexbll's post
Hi everyone
Good morning, let me introduce myself briefly, I'm writing from Italy and I own a ford fiesta mk7 1.25 82hp 2009
Apr 11, 2026
Lots of trouble codes, car runs fine
Thanks. Yes the codes are from her car. Car info is in pic 2. I did have the driver side kick panel connector disconnected when...
Apr 11, 2026
Bigjakester
Stalling issue, questions about data points
2012 ford fiesta 1.6l NA Manual Only fault code is P0627 Engine stalls/dies only when going 40-60 mph, low RPM, little or moderate...
Apr 11, 2026
Hi. The car has been running fine after I completed that engine swap last summer. Occasional engine light, which was always MAF. Cleaned...
Apr 10, 2026
Glad you're alright and hope replacing wiper blades doesn't put you in traction at the local hospital - wish you the best and glad to...
Apr 10, 2026
Lexbll
Front noise problem
Hi, thanks for the reply. I bought the car, but since it had been sitting in the garage for a while, I thought I'd replace both the...
Apr 10, 2026
Lexbll
Front noise problem
Wheels, Tires, Chasis, Brakes & Suspension
Good morning, i have a ford fiesta mk7 1.25 82hp 2009, I bought it in September 2025 used with 25,000 miles, it did very few miles a...
Apr 10, 2026
Learn moreā¦
