weedog
Seal on 2006 ZX4 ST PS
The seal i need is for the passenger side. Thanks
May 1, 2026
weedog
Does anyone know where to get the seal where the cv axel goes on the shaft coming from manual trans on the 06 St. did not have no luck...
May 1, 2026
Clutch pedal assembly
Yes the it did came off fairly easy and installed fairly easy too ,just twist and remove and here the part number for the assembly
Apr 30, 2026
Did the Starter Switch line up OK, or did it come with a new one? Thanks for these pics, makes for a good archive of the event -...
Apr 30, 2026
I may add i went ahead and replaced the whole unit simply because of the age and those plastic parts get brittle and break easily, so...
Apr 29, 2026
Actually what i did after watching what ever videos i could find. Took intake and battery out with tray ,clean every with degreaser...
Apr 29, 2026
Remember when you open this can of worms, the clutch uses the line from the master cylinder. There are threads here - but not all have...
Apr 29, 2026
Y
YasmimWest
Don't know where the main ground cable goes...
Hi! Did you manage to find it? I had to take it apart to replace the clutch disc and I also forgot where it was attached 😅😅
Apr 27, 2026
ghostcot
Ford Fiesta Window Sticker Lookup
I tried it, but sadly it doesn’t work anymore. Would be great if someone knows a current working alternative.
Apr 27, 2026
vviktor
Ford Fiesta Dashboard Clock Cluster Error
DTC error codes c100, c121,9317, E510 I can't delete these, so maybe they're old
Apr 26, 2026
vviktor
DTC error codes c100, c121,9317, E510 I can't delete these, so maybe they're old I'm starting over now, just to be safe. I took out...
Apr 26, 2026
Folocofan
Estate rear seat problems
Hi all, I recently bought a 2001 pre-facelift Focus estate. It was fitted with ST170 Recaro front & rear seats. My first problem was the...
Apr 26, 2026
volition777
jpguse12's post
Anyone here order the optional spare tire on the tailgate? What happens to the backup camera?
Do you have part numbers for the tire mount, rear camera and bumper?
Apr 24, 2026
Well hi there peeps!! is been a hot minute since i been around but today my Fiesta remind me of why i joined this forum in the 1st place...
Apr 24, 2026
vviktor
I have moved all the connectors, all the cables from the dashboard to the ECU, but the problem has not worsened or improved. That's why...
Apr 24, 2026
