nico38
How to calibrate blend door actuator
Hello, My friend is having trouble with the blend door actuator in her Ford Fiesta VII 5 doors 1.0 SCTi EcoBoost 12V mHEV S&S 125 cv...
May 8, 2026
Krosamond
I got a 2018 fiesta with 75000 mile a few months ago . Auto transmission shifts between 2500 to 3000 rpm . Is that normal?
May 6, 2026
guypilar
replacement of pcv oil separator
Forum Help Center
good day guys, i want to ask someone do you have any idea how to replace pcv oil separator?
May 4, 2026
Ford Fiesta Window Sticker Lookup
The Fiesta has been out of production for several years. There is not going to be anything like a window sticker lookup website for this...
May 3, 2026
weedog
Seal on 2006 ZX4 ST PS
Dang this site is DEAD
May 2, 2026
AJKroe
new owner
I am the new owner of a 2025 ruby red Ranger Lariat. I had 24 Maverick, I liked that little truck it was a hybrid and 40 mpg was great...
May 1, 2026
weedog
The seal i need is for the passenger side. Thanks
May 1, 2026
weedog
Does anyone know where to get the seal where the cv axel goes on the shaft coming from manual trans on the 06 St. did not have no luck...
May 1, 2026
Clutch pedal assembly
Yes the it did came off fairly easy and installed fairly easy too ,just twist and remove and here the part number for the assembly
Apr 30, 2026
Did the Starter Switch line up OK, or did it come with a new one? Thanks for these pics, makes for a good archive of the event -...
Apr 30, 2026
I may add i went ahead and replaced the whole unit simply because of the age and those plastic parts get brittle and break easily, so...
Apr 29, 2026
Actually what i did after watching what ever videos i could find. Took intake and battery out with tray ,clean every with degreaser...
Apr 29, 2026
Remember when you open this can of worms, the clutch uses the line from the master cylinder. There are threads here - but not all have...
Apr 29, 2026
Y
YasmimWest
Don't know where the main ground cable goes...
Hi! Did you manage to find it? I had to take it apart to replace the clutch disc and I also forgot where it was attached 😅😅
Apr 27, 2026
ghostcot
I tried it, but sadly it doesn’t work anymore. Would be great if someone knows a current working alternative.
Apr 27, 2026
