RLM3249
2013 edge titanium climate control
Ford Edge Forum (First Generation)
My Edge temperature on the passenger side starts dropping to LOW. turning climate control off does not help as it just turns itself...
May 22, 2026
gpfan
Dead battery
Your battery is wanting replaced.
May 22, 2026
gpfan
Katarina77's post
Dead battery
Hello. Every 1-2 weeks I need to charge the battery. It charges ok. This morning it was fully charged,.and when idling it showed 13,6v...
May 22, 2026
Wellfit.Auto
AUTO START STOP MSG IN DASHBOARD
Focus ST
DEAR ALL, THERS A MINOR JERK AT 40 KMPH . CAN YOU SHED SOME LIGHT HOW TO FIX THIS ISSUE.
May 22, 2026
cpobradley
khpony's post
Keyless Key Pad
On my recently purchased 2013 Limited there's no tag in the driver footwell showing the key pad code. Anyone have any idea where else...
May 21, 2026
cpobradley
khpony's post
Keyless Key Pad
Finally found it behind a panel. All is good.
May 21, 2026
Phil77
Replacing the Auxiliary Input
I have a 2013 S with the basic radio. The auxiliary input is pure static. Is it fixable or will it need to be replaced? Easy or hard...
May 20, 2026
Razer911
Hello, I drive Thumper, a white 2015 Fiesta SE 1.6
I had to replace my coolant fan and it would not kick on i replaced the factory wiring plug and that solved my issue seems to be a...
May 19, 2026
Razer911
Hello , I have a 2015 Fiesta SE hb.
I am doing a audio upgrade front components are getting replaced w/ Infinity Kappas and the rears are getting Rockford Harley 6.5's...
May 19, 2026
LSmitrovich
Rear Hatch not working
My rear hatch is not working. For the past week, the rear hatch wouldn't open with the button on the dash, on the keyfob, the foot...
May 19, 2026
Serpentine Belt Tool
I haven’t had to replace the serp belt yet, but will soon. I have come across two types of stretch belt remover/install tools. Which one...
May 17, 2026
Earnies2's post
I own a 2011 fiesta with 309,000 miles on it
May 17, 2026
idanny76
Compressor clutch cycling quickly but air is cool
Ford Fusion First Generation
I have a 2012 Ford Fusion SEL. The AC cools and the pressure readings seem normal to me according to the outdoor temps. Outdoor temp was...
May 17, 2026
KromboCombo
2016 Fiesta SE - Sync 1 and Audio Input
That sucks, in the meantime, you can use Bluetooth to listen to music. This is going to sound weird and dumb and crazy but the sync...
May 16, 2026
KromboCombo
Just hit 100k on my 2014. It just doesn’t die
May 16, 2026
