Shredded Dried Belt > Engine Misfire Trouble Codes
GnarlyBus
La Pine
OR
2012 Ford Fiesta
My wife was driving her 2012 Fiesta (which she loves) and it shredded its serpentine belt. When this happened, the engine lost a lot of power and was limped home a mile.
Honestly, the belt should have been replaced as it was old and dried out. Some of the belt jumped onto the engine side of the crankshaft pulley and was melted into bits. I cleaned that out and replaced the belt, but the engine still sounds like it's misfiring with low power, hard to start, etc.
My current theory is that the serpentine belt jumping over may have slowed the crankshaft pulley enough to cause the timing belt to jump a tooth. Is that possible?
Is the MAF sensor possible bad or is that code pointing to a misaligned timing belt?
I appreciate your help!
Here are the DTCs:
Pre-Existing
P0054 - HO2S Bank 1 Sensor 2 Heater Resistance - ORDERED
New
P0068 - MAF/MAP Sensor Throttle Position Correlation
P0340 - Camshaft Position Sensor A - Bank 1 Circuit Malfunction
P0365 - Camshaft Position Sensor B - Bank 1 Circuit Malfunction
P0300 - Random/Multiple Cylinder Misfire Detected
Pending
P0017 P - Cam/Crankshaft Pos. Correlation Sensor B - Bank 1
P0016 P - Cam/Crankshaft Pos. Correlation Sensor A - Bank 1
P0340 P - Camshaft Position Sensor A - Bank 1 Circuit Malfunction
P0365 P - Camshaft Position Sensor B - Bank 1 Circuit Malfunction
P0300 P - Random/Multiple Cylinder Misfire Detected
175
151
I would check your crank position sensor to be sure it hasnt been damaged or miss aligned. Also look at any harness in the area that may have been grazed or damaged as well.
Depending on how deep the belt went behind the pulley I would also keep an eye on the crank seal to be sure it dosent develop a leak.
If all is good report back
Good luck
1,489
I concur with @SyntheticAtmosphere - this sounds like it jumped time and your on borrowed time with the internal belt may have suffered the jump along with the serpentine belt shredding itself.
It may need two belts (Internal timing and Serpentine) and possibly a water pump replaced - because the internal timing belt also can affect the housing the water pump is.
So for the serpentine to shred, usually means the water pump pulley and the pump itself are suspect as to be possible faults to cause the serpentine to fail - along with the AC compressor and the Alternator.
Your current list of codes shows and confirms this
G
GnarlyBus
La Pine
OR
2012 Ford Fiesta
Thank you for the responses. I appreciate your time.
We decided to take it in to the mechanic, but I will report back when we get the problem confirmed and repaired.
I did look closely at the crank position sensor wiring harness when I was replacing the serpentine belt and it was visually ok, but I did not test it with a multimeter. I didn't check the alignment of the sensor. The crank seal is OK and not leaking.
G
GnarlyBus
La Pine
OR
2012 Ford Fiesta
As suspected, this turned out to the timing belt. The mechanic is going to fix it and replace the water pump at the same time. Thanks for the help!
