- Messages
- 1,493
- Likes
- 1,164
- City
- Grand Rapids
- State
- MI
- Country
- United States
- What I Drive
- 2018 Ford Fiesta SE HB
Although scattered in the forums, there are threads about "Timing Gear" Timing Belt - along with several others, that might help you.
Just so a search for those subjects above to help start you down that path, because once the aspect is lost, the Crankshaft Gear needs to be replaced with a new one and the timing reset to OEM by setting Crank and Cams to TDC and use a kit to force and clamp the timing correctly to TDC so the belt, gear and pulley can be replaced and put back in aspect to each other.
