Bilstein B6 struts and shocks. If you are installing them, post impressions and questions here....
Do it, you'll like it!
May 17, 2025
Drum brakes park brake adjustment?
The adjusters have to be manually done by removing the wheel and drum, then turn the adjuster until the drum - slides on with a slight...
May 17, 2025
2012 Fiesta Sedan A/C Compressor
That's a very good explanation. And probably one of those caused the motor to burn up. The woman I bought it from said she had it from...
May 17, 2025
JoeBob's post
Hello. I recently purchased a 2018 Fiesta SE. Bought it after my 1991 Geo Metro's transmission went to hell in a handbasket. And...
May 16, 2025
DannyDee2
Welcome!
May 16, 2025
Went to the junkyard. Got a cooling fan. Got back home, my dad showed me how to check for resistance in my old fan, sure enough...old...
May 16, 2025
timberry
Fiesta 1.5 TDCI hesitation in fifth, possible throttle position wiring - what do you think?
Hi folks, I'm attempting to get the bottom of a problem with my dad's Fiesta 1.5 TDCI (2013). It hesitates in 5th gear even under a...
May 15, 2025
Engine Malfunction Service Now 1.0L Ecoboost
I would be checking the condition of your intake hoses and also the tightness of the attachment clamps. You aren’t giving us much...
May 15, 2025
brennynoah
Hello, I drive a 2014 Ford Fiesta 1.0L T and i’ve been having this issue for a while. When I’m not on the accelerator, every 20ish...
May 15, 2025
Dum B
2015 SE 1.6 Overheating @idle +A/C blowing warm air
Hello @hamhawk, Were you able to solve your issue? Can you share what the cause is? Thank you
May 15, 2025
Ok. I think I may just replace the fan. It's not that expensive on eBay or Amazon. I'm not about putting very expensive Motorcraft parts...
May 14, 2025
The fan wire connector itself started smoking when I hit the ac button in my car. No hot air even though the system seems to be...
May 14, 2025
O
owboky
2007 Ford Focus HVAC
I have a 2007 Ford focus. I pulled apart and clean the glue off the blend door and replaced the cables. The problem I have now is the...
May 14, 2025
Got the compressor replaced. STILL no cold air. The radiator fan connector started smoking when I tried to have the system filled...fan...
May 14, 2025
Need help with stereo speaker wiring
Turns out my problem this entire time was the radio box itself. Had NOTHING to do with the new speakers. Apparently Ford's crappy radio...
May 14, 2025
