Kendollar11
Radio stays on when engine is turned off?
So, If you need to replace the radio unit, can you substitute a similar part number?
Jun 30, 2025
2013 1.6 twin clutch not starting in first
After that tutorial, the problem faded away and it slipped to the back of my mind. It woke up again today. At three consecutive lights...
Jun 29, 2025
Stretch fit belt confusion
Thanks! 6PK1030 specs say it's made of EPDM but description doesn't say stretch application like with other belts. The first time...
Jun 29, 2025
As per @scotman suggestion, can you cobble an older cigarette lighter adapter and hook up to a voltmeter thru it's test leads - one of...
Jun 29, 2025
Sagging rear - Airlift 1000 system versus stiffer coils and Bilstien B6.
You should post some pictures of your setup in the camping with the Fiesta thread. Everyone seems to find a unique way to resolve the...
Jun 28, 2025
I'd follow up on what Tabijan said, then.
Jun 28, 2025
tabijan's post
Restricted evaporator air flow and/or running low on refrigerant can cause the evaporator to ice over. There's an evaporator temp...
Jun 28, 2025
mgriffith1979
Hello Guys, I did replace the cabin air filter and the serpentine belt as well.
Jun 28, 2025
Barberryn
Starts well but sets "service engine" information and powers down engine upon shifting into 1st.
New info - After having the good luck to meet a Ford Factory Tech/Engineer, was advised about the clutch position switches. I replaced...
Jun 28, 2025
jns
2024 Ford Ranger/Ranger Raptor Retrax - RetraxPRO XR Retractable Tonneau Cover - T-80338 R
Bought and installed in November 2024 for >$2K, then had unique opportunity to replace it with a full smart-cap 8mos later. For 5.1'...
Jun 27, 2025
ijerez
Thanks for replying! I'm going to have to limit the tough weight. I had to add a riser to my tow hitch to keep the cargo carrier from...
Jun 26, 2025
ijerez
Thanks for the reply Thank for the reply! I'll purchase the airlift bags first and install. I've got camping trip coming up and the...
Jun 26, 2025
ijerez
You are not alone in wondering how a system like this could be used for load leveling on a Fiesta. I live pretty close to the Airlift...
Jun 26, 2025
Have you changed your cabin filter?
Jun 26, 2025
1.6 SOHC or SOHC?
So you know, ANY motor that had bad timing or jumped time - are subject to be called interference due to Head-to-Valve-to-Piston...
Jun 26, 2025
