Replace Ball Joint
2013 Fiesta SE hatch. The ball joints are not held in place with circlips. Can they be pressed out?
Jun 30, 2025
SidejobJoe79
no spark
made a cut down wiring loom 2005 fiesta 1.4 16v in my sons banger car now i have no spark
Jun 30, 2025
How many miles do you want out of your Fiesta, realistically?
I’m just starting to think about what is possible. I really want a DiN 2 setup, which would definitely require the removal of the the...
Jun 30, 2025
Paulinewinnie
Fiesta bumper
Hi all i have a brand new genuine fiesta rear bumper from ford with box and certificate number in race red as new still never been...
Jun 30, 2025
ketchup_burgers
I'm interested in what direction you go for your cut & gut. My SYNC is hanging on, for now.
Jun 30, 2025
Kendollar11
Radio stays on when engine is turned off?
So, If you need to replace the radio unit, can you substitute a similar part number?
Jun 30, 2025
2013 1.6 twin clutch not starting in first
After that tutorial, the problem faded away and it slipped to the back of my mind. It woke up again today. At three consecutive lights...
Jun 29, 2025
Stretch fit belt confusion
Thanks! 6PK1030 specs say it's made of EPDM but description doesn't say stretch application like with other belts. The first time...
Jun 29, 2025
As per @scotman suggestion, can you cobble an older cigarette lighter adapter and hook up to a voltmeter thru it's test leads - one of...
Jun 29, 2025
Sagging rear - Airlift 1000 system versus stiffer coils and Bilstien B6.
You should post some pictures of your setup in the camping with the Fiesta thread. Everyone seems to find a unique way to resolve the...
Jun 28, 2025
I'd follow up on what Tabijan said, then.
Jun 28, 2025
tabijan's post
Restricted evaporator air flow and/or running low on refrigerant can cause the evaporator to ice over. There's an evaporator temp...
Jun 28, 2025
mgriffith1979
Hello Guys, I did replace the cabin air filter and the serpentine belt as well.
Jun 28, 2025
Barberryn
Starts well but sets "service engine" information and powers down engine upon shifting into 1st.
New info - After having the good luck to meet a Ford Factory Tech/Engineer, was advised about the clutch position switches. I replaced...
Jun 28, 2025
jns
2024 Ford Ranger/Ranger Raptor Retrax - RetraxPRO XR Retractable Tonneau Cover - T-80338 R
Bought and installed in November 2024 for >$2K, then had unique opportunity to replace it with a full smart-cap 8mos later. For 5.1'...
Jun 27, 2025
