Cup holders
There are many travel mugs that have a smaller diameter base that fits into the Fiesta cup holder. The smaller diameter niche in the...
Jul 28, 2025
sguinn
Different size wheels depending on trim level
I have a 2020 Titanium and the tires look TINY. Weird that the lower trims would have taller tires.
Jul 27, 2025
Head gasket likely shot, engine replacement tips?
It sad to read this, because mine too, is low in miles but not THAT low [wrenchin][burnout]So I may be facing an inevitable that the...
Jul 27, 2025
Jay71
Driver Electric Window and Mirrors not working - Any advice?
Hi Andy Thanks so much for offering your help/advice, I will certainly have a look through what you've said, like you I'm not to sure...
Jul 27, 2025
mmitsch
2017 Focus Needing Work
Third Generation Focus
We took our 2017 Ford Focus in for a recall and the dealership gave us a $5,700 quote for repairs as noted below. I can do the spark...
Jul 26, 2025
AlanReid
Please Help My Overheating ford fusion
What comes to mind here is Murphys law... The most expensive part in any engine will overheat and expire first, to protect the simplest...
Jul 26, 2025
Jay71
Hi there Sorry about resurrecting an old post, it's just that it's exactly the same problem as mine. I was just wondering if you had...
Jul 26, 2025
Thank you for this. I took this one apart. No damage to the gasket itself. But both the block and head face are .005-.006 out of flat...
Jul 25, 2025
Bluesie
2019 Edge ST Factory Wheels with Tires for Sale
Wheels & Tires
FOR SALE: 21” OEM Ford Edge ST Gloss Black Wheels & Tires – Excellent Condition Price: $1,600 OBO Selling a set of genuine 21” Ford Edge...
Jul 25, 2025
Sagging rear - Airlift 1000 system versus stiffer coils and Bilstien B6.
these bags don’t “raise” the vehicle. They are set to a predetermined pressure and then you load the vehicle with the items you need to...
Jul 23, 2025
Mattyzvan
Buzzing from Engine Bay? 2019 Edge ST
I have a 2019 Edge ST and theres this like electrical buzzing coming from the engine bay. It's not from the engine but from the left...
Jul 23, 2025
Mattyzvan
Ferrada FR2 20x10.5 5x108 ET38
Wheels & Tires
Hi there, I have a ford edge ST 2019. I just saw this wheel setup and basically want to copy the exact look...
Jul 23, 2025
boogeyman
2008 Edge Steering Rack
Ford Edge Forum (First Generation)
Hello everyone, My ps rack leaks from the ps hose/banjo bolt connection. The threads are stripped. So I've been driving with manual...
Jul 23, 2025
When To Replace Rear Brakes.
Wheels, Tires, Chasis, Brakes & Suspension
2013 Fiesta Hatch SE 1.6 DOHC. How many miles do brake shoes last? At what thickness should the be replaced?
Jul 22, 2025
Mathew36963
14 Fiesta SE hatchback. Won't start.
In addition, I would like to add. Important! I fucked up and broke the bolt off in the hole designed for the ground, so I had to screw...
Jul 21, 2025
