When To Replace Rear Brakes.
Depends upon your driving habits. 2013? At least take the wheel off, mark the hub to drum so you can match mark it to keep it balanced...
Jul 30, 2025
How Much Transmission Fluid
Owner’s manual says 2.2 quarts maximum. But any amount above that will leak out past the output shaft seals anyways.
Jul 30, 2025
2017 Ford Fiesta S
I recently picked up these polyurethane fitted control arms with offset bushings that add positive caster. These are SuperPro TRC1069...
Jul 30, 2025
dragonfly0201's post
Replacing rear bumper cover
It doesn't fit totally perfect due to the accident, but it's way better than it was without one.
Jul 30, 2025
My dad actually did it for me. Paint has to set then it needs some polishing.
Jul 30, 2025
Adding a circuit or two
for those pesky mA calculations... 1A = 1,000mA while 0.1A = 100mA (10X less - just move the decimal) Say your Battery charger uses...
Jul 30, 2025
Jul 30, 2025
Third brake light?
Should be a LED on a circuit board by 2015. If you can’t find a bulb number in the bulb chart. It’s an LED. I would be checking the wire...
Jul 30, 2025
Third brake light ?
I believe that it’s an LED board. So “sealed “. I would recommend that you check the wire connections to confirm that it is not a...
Jul 30, 2025
Welcome to the forum. There’s a lot of good info here. It’s best/ fastest to use the search function to find the particular threads or...
Jul 30, 2025
E
Eddie Baird
Third brake light ?
Is the third brake light in back window of 2015 Fiesta se sedan a sealed unit or can bulbs be replaced ? Thanks , any recommendation...
Jul 29, 2025
E
Eddie Baird
Third brake light?
Jul 29, 2025
E
Eddie Baird
Hello from Richmond Virginia
Jul 29, 2025
baytimir
David H's post
Newbie here... 2020 Fusion Hybrid SE. Enjoying it so far! Averaging 44+MPG. Be well all, Dave
Jul 29, 2025
How much Ford manual transmission fluid for IB/5 transmission in 2013 Fiesta SE? I put used transmission in my Fiesta. The owners manual...
Jul 28, 2025
