Both the top and bottom hatch - the lock mechanism and the bottom latch that fastens it shut - like @scotman says, I will add that as...
Aug 26, 2025
LittleBlackCar
Radio makes battery go dead
Hi, for the past year I have had the radio fuse out of my car, otherwise my battery goes dead within 30 hours of the car not being...
Aug 26, 2025
Air con blowers not working - fiesta 2015
Did you ever get this figured out? I just went through this with my friend’s car. Could have been a lot of things, but in my case it was...
Aug 24, 2025
2013 Fiesta blower motor (power to relay coil)
Thanks for the tip about the internal folds and jumpers. I wasn’t about to tear that whole harness apart, but I would if I really had...
Aug 24, 2025
The box itself has jumpers that snake thru the plastic to feed - so you see the bluestripe wires but can't locate the break? That may be...
Aug 24, 2025
Head gasket likely shot, engine replacement tips?
Well it’s no better still. Had it Xrayed Friday but won’t know results until Monday.
Aug 24, 2025
Woof! You OK?
Aug 24, 2025
I would inspect the connection to the harness and possibly you might need to adjust the latch position “upward” to pull the hatch lid...
Aug 24, 2025
manxzetecs
Electrical issue please help
Fiesta Build Projects
hey. Bought another 2001 fiesta zetec s that has had a puma engine installed. The headlights, rear lights and dial light don't work. the...
Aug 24, 2025
Everything still looks good with the engine, so today I got back at the blower motor relay circuit. I pulled the control head and the...
Aug 23, 2025
CoJack's post
You are a very good friend
Aug 23, 2025
CoJack
Aug 23, 2025
F0RD197#
Hi everyone. I have a Ford fiesta 2016 with rear hatch alarm when driving and it's closed. Seams to happen over bumps. I replaced rear...
Aug 23, 2025
talisker
WHERE TO BUY PARTS
Thanks appreciate the advice.
Aug 22, 2025
08EdgeSEL
Intermittent Cranking
08 Edge SEL cranks intermittently. Replaced mass air flow sensor, starter, charcoal canister, starter, and crankshaft position...
Aug 21, 2025
