Orange wrench light w/ car stalls, wont start and doesnt see what gear its in.
You need to start with cleaning the ground connections on the underside of your Fiesta. There is a cluster of them near the lower...
Oct 17, 2025
2016 fiesta S. Keys now missing.... any way to bypass the anti theft key detector?
You really must “sort out “ your wiring issues. The “passive “ part of “passive anti theft”doesn’t mean easy to defeat or trick into any...
Oct 17, 2025
MK8 Dashboard Mats/Covers?
The U.S. and Canada never got the Mk8 Fiesta. Early in my ownership of my Mk7 Fiesta I had the same issue and resolved it by purchasing...
Oct 17, 2025
2012 Ford Fiesta question
The control module for the transmission is vin matched to the original vehicle. You don’t mention exactly which transmission you have...
Oct 17, 2025
2016 Fiesta S, lost key
No.
Oct 17, 2025
Frustratedfiesta
Hello, I lost my key to my 16 fiesta. Is there any possible way to bypass the PATS so I can start my car?
Oct 16, 2025
2
2014FiestaHelp36963
Hi, I drive a 2014 Ford Fiesta SE Hatchback 1.6 l engine. Orange wrench light and traction control light illuminated, vehicle shuts off...
Oct 15, 2025
Straitsfan
2015 Fusion -- no sound.
This happened September 5: Radio on, then heard a lound, sharp crackling sound and then no sound. Thought it was the station...
Oct 15, 2025
Jonh
Okay so I'm currently swapping out the motor in the transmission in my 2012 Ford Fiesta and I'm getting the motor and a transmission...
Oct 14, 2025
If it's black, it's an aftermarket intercooler. You can learn more about it on the ST forum. https://www.fiestastforum.com/
Oct 14, 2025
Ran low on coolant, now starts rough/rough idle that mostly clears
When you run low on coolant - this may mean the engine needs more service than you can afford - the coolant prevents the car from...
Oct 13, 2025
Oct 13, 2025
KrayZJay's post
How’s everyone doing? I bought my 2018 Fiesta ST a month ago and this is the best car I’ve ever owned hands down. It came with some mods...
Oct 13, 2025
Fiesta poor downshift to 1st
Still not on the road. Finished bleeding the slave cylinder, then the clutch master cylinder broke. The plastic rod connecting the...
Oct 13, 2025
Fiesta Fanatic
Forum Help Center
Hi there. I recently acquired a 2022 Fiesta ST-Line and have found the shiny dashboard reflects on the widescreen quite noticeably at...
Oct 13, 2025
