vviktor
Ford Fiesta Dashboard Clock Cluster Error
I have moved all the connectors, all the cables from the dashboard to the ECU, but the problem has not worsened or improved. That's why...
Apr 24, 2026
vviktor
Sorry for the translator, I copied something wrong, I didn't see it. All units are original, and it does the job. I have a car with...
Apr 23, 2026
FBLeMans
À LA RECHERCHE D'OEM FORD 1104435 – Fiesta MK4 Endura-E 1.3 (1999)
Bonjour, Je recherche un collecteur d'admission (La référence exacte est 1104435) pour fiesta 1999 Pourriez-vous m'aider à trouver une...
Apr 22, 2026
FBLeMans
Fiesta MK IV 1999 - Collecteur d'admission
Want To Buy
Bonjour, Je suis en galère avec ma Fiesta de 1999. Je recherche désespérément un collecteur d'admission Référence 1104435...
Apr 22, 2026
vviktor
Nagyon szépen köszönöm a válaszát Ritkán kapcsol ki a rádió, vagy tűnjön el a jelzőfénye Nem az óra, hanem a...
Apr 21, 2026
marcellaallum
Fiesta 1.0 EcoBoost 63k Engine Issue (Oil Pump) – Advice / Parts Interest
Hi everyone, Looking for a bit of advice and also putting the feelers out in case anyone might be interested. My Ford Fiesta 1.0...
Apr 21, 2026
Htsjups
TGE value error
Hi Dears, I’m user of ford fiesta 1.4 At, I have some issues with my transmission, gear 1-2 not smooth, some time 2-3 Rpm going higher...
Apr 21, 2026
Jenni green
98 Ranger with rear wheel brake having slight drag (1 wheel only)
Mine is 1993 I did all the same things as you. Did you ever figure it out?
Apr 20, 2026
Jenni green
Brake drum
Ford Ranger Discussions (1983–2011)
Replaced rear drums, now passenger side is dragging. Why?
Apr 20, 2026
Sarahfielder009
Overfilled engine oil
Engine Performance
So a friend of mine put too much oil in my engine and before I knew it, we drove about a half mile. The engine started putting so we...
Apr 20, 2026
vviktor
Hello! I have a 2007 FORD JC3 Fiesta Van 1.4 tdci MK5. Engine code: F6JB My problem is that the clock often drops the hands, the LCD...
Apr 20, 2026
ChaddyBoy
Ignition switch fails to recognize key is inserted/turned - Intermittent "No Start"
Third Generation Focus
Hello. I'm new here, and to forums in general. I couldn't find a better place to post this. I'm mechanically inclined and have worked on...
Apr 17, 2026
Polejockey
2014 SE Tranny Issue
Hello everyone. This is going to be a little long but I need to convey exactly what is going on. My wife's 2005 focus was t-boned and...
Apr 17, 2026
What are your tips for general maintenance ?
If you haven't already done so, might want to take a look at on-line Ford Parts dealers and see if the year you have - they still can...
Apr 15, 2026
Abbe
Engine Rattle
My 2015 Fiesta with 72000 miles has a loud rattling when idling and going less than 30 mph.
Apr 14, 2026
